ive just started using ableton and virtual dj and now i want to buy a mixer.
ive been looking in to the BEHRINGER DJX 700 which is in my price range and seems decent but
ive heard alot of bad reviews about it and some good.
are the BEHRINGER DJX 700s any good?
im looking for recommendations also, i would love something with lots of effects, i am a beginner
so im looking for something simple and cheap.
cheers
cheers
Posted Tue 08 Apr 08 @ 3:48 am
no
Posted Tue 08 Apr 08 @ 6:41 am
Go for vestax , no effects but better sound - Behringer Is very very BAD
Posted Tue 08 Apr 08 @ 6:47 am
uuuuuhhhhhh behringer ??? no
if you can spring for another 100 $ or so you'll be glad you did , and spend it on something more reputable ......
also it will not be a heavy duty piece of equipment ........
Posted Tue 08 Apr 08 @ 6:52 am
Cheap and good don't go together ;)
Check out some Numark gear. Avoid Behringer for mixers.
Posted Tue 08 Apr 08 @ 12:03 pm
Check Numark DXM09 pretty good price and nice 3 channel mixer with effects. Man!! I regret selling mine.
Posted Tue 08 Apr 08 @ 12:07 pm
i got a berihnger djx 700 it thinik is alrite for da price and da efcts r pretty good
Posted Wed 09 Apr 08 @ 8:01 pm
Well, I have this mixer as well, and I can only say one thing about it...
Just like some one else said on this forum about it, its the Taco Bell of mixers...
Posted Wed 09 Apr 08 @ 10:38 pm
Numark, behringer, gemini, american audio are all in the same category... I owned a rane mp24..." Biamp scm7600 The best of all time... " Denon X800,X900, X500, urie 1610 Pioneer DJM 500. and many more. A good mixer is made durable and it has a strong fader. Low cost mixers use faders that can be replaced because they dont last as long like a good mixer.
Posted Thu 10 Apr 08 @ 1:32 am
