Hello,
I was wondering ... when i use vurtual Dj Pro ... when i have 2 tracks playing ... ok so 1 track playing and the other one i am trying to mix (i am using headphones) but i when ir ecord it sounds crappy as you can hear me trying to beatmatch the other tune .. so what i am asking is how do i listen to 1 tune thru my headfones and its not comign thru the actuall recording untill i put the crossfader up when i have my mix spot on just like on my real dj decks? If you know what i mean ... if there a setting or a plugin for this?
Sorry if this is the wrong section , please move it if so.
Posted Fri 04 Apr 08 @ 5:57 pm
What are your system specs? What version of VDJ are you using? What is your external controller?
Posted Fri 04 Apr 08 @ 6:07 pm
Virtual DJ 5.0
Internal Mixer Interface
And umm what system specs?
Posted Fri 04 Apr 08 @ 6:23 pm
What kind of computer are you using..and what are its specifications, I.E. processor, memory, hard drive size and speed.
Posted Fri 04 Apr 08 @ 7:02 pm
