Hi,
I have VDJ5 running on MacOSX10.5 controled by Hecules MKII interface.
I´ve been testing a little but i can´t find the way to set it up the way i need it to work.
I need to create 2 playlist,one for each "cd".Leave all the tracks in touse playlists and triggering one after the other.I don´t want to use mouse to select every track ,
click and throw it on the "cd" i want to use.
I don´t pretend to mix,just play tracks one after the other.
Is any way to set vdj5 up to work this way??If it is not possible with VDJ5,is there any program that works in that way an can be controled with Hercules interface?
Many thanks,
Ray-
Many thanks,
Ray-
Posted Fri 04 Apr 08 @ 4:09 am
It would be possible via Auto mixing a playlist in V5 , which you would need to purchase as there is no mac demo..
or perhaps if you would prefer a sequencer www.mixmiester.com , Mixmiester Studio MAC would meet your needs it also supports midi controllers via mapping.
Posted Fri 04 Apr 08 @ 5:57 am
tnx skyfx,
i´ve got VDJ 5 already,how can i set up that automix function??
It would be awsome if you tell me how...
Thank you again
Thank you again
Posted Sun 06 Apr 08 @ 12:51 pm
You need to do is add your serial so you can get the latest stable full version 5.07 pro
http://www.virtualdj.com/fusers/modifuser.html
and then grab a copy of the V5 Guide from here , http://www.virtualdj.com/support/
hope to see you as a registered user soon.
Posted Sun 06 Apr 08 @ 12:56 pm
