whats going on everyone. i started have this problem lately and i cant seem to be able to fix it. i tried uninstalling mk2 and virtual dj but no luck. the problem is when i turn any nob bass mid and treble , volume , crossfader or any key. the music starts to crackle.but it stops when i dont touch anything. here is my system i got a pentium 4 2.8 ghz 3500 mb of memory and 160g hard drive. i tried adusting the performance slider but no luck any one have any clue? thanks for any help
Posted Wed 02 Apr 08 @ 12:43 am
Have you downloaded the latest drivers ?
Posted Wed 02 Apr 08 @ 6:12 am
yes i have . and no luck. can it be that i have to much memory ?
Posted Wed 02 Apr 08 @ 8:22 pm
What are you settings in the Sound setup tab?
Posted Wed 02 Apr 08 @ 8:59 pm
Try turning on or off safe mode.
Posted Thu 03 Apr 08 @ 3:14 am
my seetings are
input: none
output: headphones
sound card :mk2
master channel 1&2 headphones 3&4
the performance settings slide bar is all the way on fast if i move it forward the sound is terrible.
how do i turn off safe mode?
input: none
output: headphones
sound card :mk2
Posted Thu 03 Apr 08 @ 9:02 am
In VDJ Config/Perfomances/untick the box next to Safe Mode.
Posted Thu 03 Apr 08 @ 9:31 am
bedaddj wrote :
my seetings are
input: none
output: headphones
sound card :mk2
input: none
output: headphones
sound card :mk2
If you were to look under the mk2 startup you will notice that the mk2 has switched itself into asio mode which will conflict with your setup.
Go into VDJ and change sound card to 4.1 and channel should change to front/rear > then go back into MK2 start up and change the push button to WDM.
This should cure your cracklin also update the mk2 drivers to 2008 if you havent already.
NOTE: This only applies the VDJ 5.07...
Posted Thu 03 Apr 08 @ 12:07 pm
i am not using vdj 5.0.7 i am using the first 5.0 vdj . i went back to this version from the 5.0.7 because it had alot of issues.the sound when it comes out works fine. its when i try to use any nobe on the mk2 then it starts cracking. for example if i have a song playing on the first deck and i try load up deck no2 . now if i use any button nob or crossfader the sound cracks . even when the vol for dec no 2 is off.its an odd thing never had that happen before. i am going to try the safe mode thing and write back thank you all.
Posted Thu 03 Apr 08 @ 2:53 pm
The 5.0.7 issues are resolved with the NEW Mk2 drivers if that is why you went backwards.
Posted Thu 03 Apr 08 @ 4:08 pm
Or if it isnt checked check it. Some systems work great with it on and some with it off.
Posted Thu 03 Apr 08 @ 7:04 pm
i am going to do the update and see what happens thank you
Posted Fri 04 Apr 08 @ 9:12 pm
