I DJ OFF MY PC WITH PCDJ FX AND I NOW WANT TO SWITCH TO VIRTUAL DJ. I'M TRYING TO SET UP PLAYER A ON VIRTUAL DJ TO PLAY ON THE MIXER ON CHANNEL 1 AND PLAYER B ON VIRTUAL DJ TO PLAY ON THE MIXER ON CHANNEL 2. I USE A EXTERNAL SOUND CARD TO HOOK UP THE LAPTOP TO THE MIXER CAN VIRTUAL DJ BE SET UP THAT WAY?
Posted Tue 01 Apr 08 @ 9:19 pm
AND DOES VIRTUAL DJ HAVE A AUTOMIX BUTTON
Posted Tue 01 Apr 08 @ 9:20 pm
Hi DJSLEEP224
Please turn off your Caps Lock, it looks bad ;)
Yes, you can setup Virtual DJ the way you described with 4 channels sound card and selecting "External Mixer" option in VDJ.
Virtual DJ has Automix button and you can setup it the way you wanna perform in settings also.
I suggest you to try our latest demo:
http://www.virtualdj.com/download.html
Posted Wed 02 Apr 08 @ 6:17 am
