hello I has now everything attached to maya the etc., but I have all 2 sounds of the TTs only on a channel. what can lie?
Posted Fri 17 Dec 04 @ 7:00 pm
The problem can comes from your cracked version 2.04 or 2.06...
We don't support a cracked version.
Posted Fri 17 Dec 04 @ 7:26 pm
no i have the demo version
Posted Fri 17 Dec 04 @ 7:27 pm
but the demo version is 0 days avaible. can it therefore are`? it wants to only know that it is appropriate if I for full version buys wants I to have all this functioned
Posted Fri 17 Dec 04 @ 7:31 pm
Full version and maya44usb are working very well with one or two turntables.
Posted Fri 17 Dec 04 @ 8:31 pm
ok i buy the original. and then all work?
Posted Sat 18 Dec 04 @ 3:25 pm
POSSITIVE +++++++++++++
Posted Sat 18 Dec 04 @ 5:26 pm
Come on as a full user; it worths the price trust us.
This is the best PC-DJing software. It works very well.
Posted Mon 20 Dec 04 @ 5:34 am
in the full version
does it have the
Low Latency Timecode" configuration (the image with turntables, at the bottom of the list).
because, im using the demo and it doesnt have it, it only goes as far as the dj hercules
does it have the
Posted Fri 24 Dec 04 @ 2:50 am
I think yes that I don't have TC vinyls so I cannot answer you at 100%.
Maybe someone else ?
Posted Fri 24 Dec 04 @ 9:20 am
thebachelor: stop using a bugged cracked version, and buy a legal full version
Posted Sat 25 Dec 04 @ 5:57 am
