Hey,
I have been using VirtualDJ for my Shoutcast server, but there is one problem. The integration is great, but you do not have the option to set all the variables for the Shoutcast server. This causes the URL for the stream to be set to http://virtualdj.com, which is just a cosmetic problem. It also doesn't allow me to set other parameters, such as AIM and IRC. I think that we should be able to set these, we bought the software and all.
Thanks,
Anthony
Thanks,
Anthony
Posted Fri 28 Mar 08 @ 5:51 pm
What version of VDJ are you using? Also use the Search feature look up Ultimate Guide To Broadcasting, see if your answers are there...
Posted Fri 28 Mar 08 @ 6:02 pm
VirtualDJ 5 Pro
Can you link me?
Can you link me?
Posted Fri 28 Mar 08 @ 6:05 pm
Enter your serial number into your profile and I think you'll get a better responce from the brilliant users on this site. Just my 2 cents.
Yosef
Yosef
Posted Fri 28 Mar 08 @ 11:41 pm
