When i load songs on Deck A or Deck B, both are seen ONLY on Deck b. Everything else works fine (headphones, cues)
How do i get it so that when i load a song on deck A its on deck a, and when on deck b its on deck b and not overlapping?
Posted Sun 23 Mar 08 @ 2:45 pm
There no mac trial version atm!
U can upgrade heren u have a discount as u own the djc edition.
And grab the updates
Hope to see as a pro user soon.
Posted Sun 23 Mar 08 @ 2:52 pm
Unfortunately as you are using an old beta it will never work.
You will need to purchase the upgrade and download the latest version free to all pro users which gives full functionality.
Posted Sun 23 Mar 08 @ 2:56 pm
Will the program still run and work as it should, if i do not upgrae?
Posted Sun 23 Mar 08 @ 3:09 pm
No! They are beta n there are problem but the latest version, the official v5.07 release have fix most of the problem.
To ensure good n smooth application running, I would suggest u should upgrade n use the official release instead. With Pro status u can dl both the mac n the pc version (2 system at all time - 2 pc/2 mac or 1pc n 1 mac). N also get the plugins n upgrades free.
Regards;)
Regards;)
Posted Sun 23 Mar 08 @ 3:15 pm
