So basically I have everything matched up perfectly & at a certain point my tracks just go out of sync as if there was a bump in the timecode. Can someone tell me if there is a small problem with the timecode. I have used different pcs as well, different burners. I am really frustrated at the moment. Before anyones says tracks go out of sync, yes I know. But they go gradually out of sync, not a sudden bump. Does this happen to anyone else. I can remeber seeing someone posting something similar. I also have 100 percent signal. Also my setting are perfect.
Help would be appreciated
Posted Sat 22 Mar 08 @ 1:00 pm
check ur pitch sensitivity..that might be it
Posted Sat 22 Mar 08 @ 1:06 pm
Try pitch sensitivity to 2000ms
By the way, what CD players ? NO turntable or CD player on earth spin perfectly, so it will drift... But over time
How fast is it out of sync? With a good CD player, that sould take several minutes to drift out of sync
Posted Sat 22 Mar 08 @ 1:22 pm
ok I will try that but Im not so confident:( My players are the cdj200s with a pitch resolution of 0.02. When perfectly beatmatched as you said, they should stay in sync for quite a while.
Posted Sat 22 Mar 08 @ 1:38 pm
what soundcard are u using and is it on a HUB..if not try a powered hub..maybe usb is losing power...
Posted Sat 22 Mar 08 @ 1:51 pm
using the maya44USB. Connected directly to the pc. Tried that out, it seems to help a little but on regular cds I can still beatmatch way better. Think Im gonna just use ordinary cds:O Ahh crappness:(
Posted Sat 22 Mar 08 @ 1:59 pm
VDJ and Real CD's should be exactly the same.. Real CDs will drift on CDJs 200 too, but takes quite a while, and so should timecode.
If timecode drifts faster, there is something in the settings, possibly latency.
If you are using maya, you MUST use latest drivers (alternatively Asio4all) , and you MUST use Auto for latency in VDJ performance tab.
Posted Sat 22 Mar 08 @ 2:11 pm
I have auto in my latency & I have now in the maya44 control panel put the latency to the lowest. Was spinning a few tracks there & mixes them flawlessly without having to touch the jog wheel at all in the mix:D:D:D:D:D
Thanks guys. & to think I was gonna go back to cds, trying to read of a tiny display:O:O Also Im curious to why I must have the latest maya44 drivers? What has this got to do with the pitch if I may ask?
whoop whoop VDJ FTW!
Posted Sat 22 Mar 08 @ 2:38 pm
So it works now? Great :)))
The drivers, well, maya's older drivers wherent good. Thats why I said latest drivers. But guess you got them ;)
Posted Sat 22 Mar 08 @ 2:45 pm
so I thought it worked great:( I will try to give my best explantion.
I know the exact problem now. So I have the tracks beatmatched perfectly so they will stay in perfect sync for about a minute & a half. When beatmatching at the start of the timecode they are perfect for over two minutes. I cue up the tune when I want to put it in again & it stays matched up for about 20 seconds. Then I have to move the jog wheel.
Its as if the timecode is now reading as If I have moved my pitch by about 0.05, thus making a complete mess to my mixes.
I think there is a point in the timecode where the timcode increases but I don't know where. I'm sure some other people have noticed this as well.
Hope to get this fixed soon:(
Posted Tue 25 Mar 08 @ 12:39 pm
bump!
Posted Tue 25 Mar 08 @ 3:28 pm
