Dude, are you running VDJ with your U46dj? HELP! I got the new one and can't get it to work, check out my topic titled "error in asio driver"
Posted Fri 28 Mar 08 @ 6:50 pm
I'd like to add my conclusions to this TCCD issue...
As I have stated in a few posts in the past, I have an issue with TCCD and version 5.0r7. I have tried previous versions of v5 and the same symptoms occur, however I do not have any timecode cd issues with version 4.3r12! My soundcard setup has not changed (Connectiv) but the cd players have.
Symptom:
Set a hot cue/loop in point with the cd player controller and let the song play for 64 counts and then go back to that cue point or press loop out to create your loop and see what happens...with me it does NOT go back to the point the hot cue/loop in was set.
This happens using Denon DND-6000 dual deck, Pioneer CDJ 1000, Pioneer DVJ-1000!!!! So tell me it's not 5.0r7 because this does NOT happen with 4.3r12!
Again nothing has changed but VDJ version and different types of cd players.
ps: How long does the play buttons last on the Numark DMC2 controller? I've been using it for 3 nights a week since around January and already starting to have issues of it miss-firing (hit play and it doesn't do anything).
Symptom:
Posted Sun 30 Mar 08 @ 2:51 pm
