OK This may be easy but it got me into trouble this weekend. I have a laptop that I run video ion for slide shows by hooking it up to a big screen TV. When I hook up the VGA cable to the TV it and open up the second monitor the picture goes black after about 5 seconds of running the video. Then when I try and readjust the resolution I the same thing happens. What do you think is causing this? No matter what screen resolution I use I cannot keep the picture up on the big screen TV
Posted Mon 17 Mar 08 @ 2:00 pm
Did you enable "extended monitor" or second monitor, in Windows display settings?
Right-click desktop,and go to monitor properties.
(btw, this can ONLY be done, WHEN the 2nd monitor is connected)
Posted Mon 17 Mar 08 @ 2:46 pm
The monitor or projector has to be connected before you boot up the laptop.
Posted Mon 17 Mar 08 @ 3:43 pm
