If i hook up 2 CDJ 400's to the computer, how can i assign player #1 and Player #2 to the software? Will i be able to controll each individual player in VDJ with the CDJ 400's?
Posted Fri 14 Mar 08 @ 4:04 pm
hy,
first sorry for my poor english
look at your cdj 400 's manual , you must change on one cdj , the midi channel , by default , all cdj are on the first channel , so put one of them on channel 2 and then assignate function with general Midi. Some mapper are available , look at external tools for vdj.
DJ Julien
DJ Julien
Posted Fri 14 Mar 08 @ 4:46 pm
I bet native plug-and-play support will come soon within VDJ itself.
But as of now, as Julien says, it can be mapped manually, even premade midi mappers for download...
Posted Fri 14 Mar 08 @ 6:33 pm
There is also a pluggin available on the Pioneer page....but the LEDs do not light with either, and no time/text info..also the scratch feature is too slow with both.......I hope your Right Rune.....native would be best..I got the cool platters design and my CDJ-400 sitting here waiting for it to be plug and play like my iCDXs were.......
Posted Fri 14 Mar 08 @ 7:04 pm
Thank you guys...
Do you think as a controller (cdj400) for virtuald dj will be much superior than the Dac3, DMC2 or any other controller up there?
Posted Mon 17 Mar 08 @ 1:05 pm
I own a CDJ-400, along with the Total Control, BCD2000, and two iCDX units...right now..I put the CDJ-400 at the same level as the BCD2000, that is only because native mapping is not available. I am sure once it is it will be a great controller. Right now my iCDX or Total Control are my favorites.
Posted Mon 17 Mar 08 @ 2:25 pm
