Need a 42" 1080p monitor, check here, for $800.00. Keep in mind they are refurbished, which means they were returned. They may have some blemishes, but work fine. I bought 2 37" models last year for under $550.00, from Buy.com. The reason I went with 37" is, they have to fit in my minivan, with a full system and full light show and truss system. I also work by myself most of the time, and have to be able to put on truss by myself, and load into the van. They also allow me to stay within my weight range of the truss. Go to BJs, Sams, or Costco and see if you can lift them in the box, your arms may not be long enough. You will not be able to send them back to Tiger, in case something is wrong, so see if the driver will let you look at it. They are not suppose to, but I was able to convince him, with my charming ways. Then again, you just may want to put this in your family room.
Posted Tue 04 Mar 08 @ 12:03 pm
Also check refurbdepot.com, 90 day warranty factory sealed very happy with mine.
Posted Tue 04 Mar 08 @ 12:46 pm
Are they sure that weights 60lbs? I swear i can lift mine easier then 2 turntables. I have that same one, even at $999 new its a killer deal.
Posted Tue 04 Mar 08 @ 3:14 pm
I'm not sure if they are talking with the box. My 37s are about 41lb, without the stand.
Posted Tue 04 Mar 08 @ 3:25 pm
I'm not sure either but i can grab mine from the middle at the top and bottom and walk away with it to another room. I find myself watching HD channels with shows i dont even care for BUT they look so nice i can't stop. Hot girls in HD look even hotter!!
Posted Tue 04 Mar 08 @ 4:18 pm
The weight was not the problem, as far as picking it up. In the box, it was a stretch to carry and load. Also the extra space I would have needed in the van. Actually, I'm getting a new van, so need to check to see if it has a extra inch.
Posted Tue 04 Mar 08 @ 4:32 pm
i can dig it, i dated a girl like that once............ i said once.
Posted Tue 04 Mar 08 @ 4:34 pm
I see that smile on your face. You still thinking about her, right now.
Posted Tue 04 Mar 08 @ 4:37 pm
