The good news is that Pioneer have just released the ASIO drivers required to use the CDJ-400 as a soundcard with computer DJ software.
Link to the install program is here:
Download -> http://www.prodjnet.com/support/download/CDJ-2000/Pioneer_CDJ_Driver_1.102.exe
Posted Mon 03 Mar 08 @ 8:32 am
Posted Mon 03 Mar 08 @ 1:11 pm
Nice, now we just have to wait for native support to get the fullest out of VDJ :)
Posted Tue 04 Mar 08 @ 1:54 am
Thanx for the links..
Well lets hope that there will be a perfect mapping (like iCdx) soon and all configurations problems will be solved :-)
/Fredrik
/Fredrik
Posted Tue 04 Mar 08 @ 12:39 pm
Can someone please help me?
I downloaded the driver and installed it.
Than I connected the cdj-400's.
My Remote Controle is:
- general midi
My Sound Setup is:
- inputs: timecodes
- outputs: external mixer
- soundcards: asio drivers
- asio driver: pioneer cdj400 asio
- input channels: chan 1&2 left deck / chan 3&4 right deck
- output channels: left deck chan 1&2 / right deck chan 3&4
Is that owkay? Because VDJ says that there are to many channels..
thank you...
- general midi
My Sound Setup is:
- inputs: timecodes
thank you...
Posted Tue 23 Dec 08 @ 11:56 am
The CDJ-400 are output only .... you can not use them with timecode.
Posted Tue 23 Dec 08 @ 12:09 pm
so i've got the cdj 400 and want to use the virtual dj along wit it....
now is there a specific version of virtual dj i need to have to be able to use my player on the vdj???
so far my sound is setup as
-INPUT: none
-OUTPUT: external mixer
-SOUND CARD: 2cards
-SOUND (1): cdj 400
-SOUND (2): cdj 400
the part i dont get is how to set the "REMOTE CONTROL" features...
i need help wit that please!!!
i can control the sound wit the mixer when i play a song off my laptop, but the cdj seem to jus sit there...
hope im makin some sense...
-INPUT: none
-SOUND CARD: 2cards
-SOUND (1): cdj 400
-SOUND (2): cdj 400
Posted Sat 16 May 09 @ 2:32 am
NO NO NO..
Posted Mon 18 May 09 @ 2:24 am
Last I checked VDJ has native CDJ400 support.. No need for timecode, just plugin USB and set the CDJ to PC mode and select the CDJ400 as input device in VDJ..
Again last I checked..
Posted Tue 19 May 09 @ 2:16 pm
If you are experiencing any issues relating to your ASIO SOUND DRIVER when opening your Virtual DJ 6.0, go to his site and download the software to fix the issue: http://www.asio4all.com/
As soon as you download, open up your virtual DJ and everything will operate normally without any ASIO ERRORS!!!!!
Posted Thu 02 Sep 10 @ 1:43 am
I have tested ASIO4ALL with CDJ-400 and was not the best, the Pioneer ASIO driver is really better and compatible with all the Windows OS, 64 Bit also!
Driver ASIO Pioneer v1.102 for CDJ-350, 400, 850, 900 & 2000
Posted Thu 02 Sep 10 @ 1:46 am
hola:
miren acavo de comprar un denon hc 5000 y no puedo hacer que funcione con virtual si me pueden ayudar seria muy util
...muchas gracias y asta luego.
Posted Tue 08 Mar 11 @ 7:43 pm
Sorry, this forum is for English language messages only.
Please either re-post your message in English or post it in the correct language forum http://www.virtualdj.com/forums/index.html
Also, if your message does not have anything to do with Pioneer CDJ-400 ASIO drivers (You mention HC5000, so this is probably the case), then please open your own new topic rather than hijacking an existing thread that is unrelated to your question.
Posted Wed 09 Mar 11 @ 4:23 am
Is this also campstible with Mac OS X?
Posted Sun 26 Jun 11 @ 5:00 pm
καλησπερα , ψαχνω να βρω ενα LINK για τους drivers PIONEER CDJ 450 , μπορει καποιος να με βοηθησει ? ευχαριστω
Posted Fri 09 Aug 13 @ 11:31 am
Please either post your message again in English or use the correct language forum: http://www.virtualdj.com/forums/7/Greek_Forum.html
Posted Fri 09 Aug 13 @ 11:38 am
The problem I have is that both cdj-400 appear in channel 1 (display and signal), and I cantĀ“make them be in channels 1&2
Posted Wed 18 Sep 13 @ 11:07 am
Please see our FAQ pages:
http://www.virtualdj.com/wiki/Decks%20inverted%20on%20MIDI%20controller.html
http://www.virtualdj.com/wiki/CDJ-400.html
You will need to purchase the full VirtualDJ Professional to be able to use CDJ-400's or any other MIDI controller: http://www.virtualdj.com/buy/index.html
If you have already purchased the full VirtualDJ Pro, then please register its serial number to your account and download the latest version from the Download Center.
Posted Wed 18 Sep 13 @ 11:32 am
plz send me the link to use nxaudio cdj700s asio driver
Posted Mon 20 Jan 14 @ 2:13 am
Your post is not related to the subject of this thread.
If the CDJ700 has an ASIO driver, it will be supplied with the product. If there was no driver supplied then a driver is not required.
If you are sure that the product requires an ASIO driver (if it is mentioned in the product manual) then you need to contact the manufacturer.
Posted Mon 20 Jan 14 @ 5:27 am
