I am running the Serato Scratch Live box and just brought the vdj program. I burned the tc cd's and it is not reading the tc. I am using a mac book pro. Is there any special settings that i need to go with?
Posted Fri 29 Feb 08 @ 11:17 pm
burned which timecode cd's? serato or vdj?
nothing special to make it work except when you pick soundcards you pick the serato box.
Posted Sat 01 Mar 08 @ 2:19 am
SSL doesn't work with VDJ on mac as there is no coreAudio drivers... This had been an on going thing for nearly a year people patitioning for them to get released but no joy!
Posted Sat 01 Mar 08 @ 3:09 am
I guess i need to get another sound card? Can anyone recommend a good one to work with this setup?
Posted Sat 01 Mar 08 @ 9:30 am
The M-Audio Connectiv Box uses core audio & Asio... It works with virtual Dj and the interface is 249.... What happened with serato, you dont like it.
Posted Sat 01 Mar 08 @ 10:28 pm
Motu Ultralite is a great soundcard. Works with both mac and pc.
Posted Sat 01 Mar 08 @ 11:21 pm
The ssl is great ...it runs flawless. I just like vdj for the features and thought i would give it a try as another choice.
Posted Sat 01 Mar 08 @ 11:41 pm
off topic: Where are you from Mark?
Posted Sun 02 Mar 08 @ 8:05 am
