hey guys. i must apologise in advance if this topic is already posted but i cant seem to find one regarding this issue.. but i just need to ask,, how do u use your headfones? meaning, how to listen to one track thru pc speakers and the other track thru headphones so u kan mix trax together properly,?? im just a begginer at this so again i apologise if this seems a stupid question. thanx
Posted Wed 27 Feb 08 @ 6:31 am
You require a usb 4.1 soundcard or greater with more than one output channel for example the Numark DJ.io
Posted Wed 27 Feb 08 @ 6:47 am
or go the whole hog, and buy a little usb soundcard like I did.... best thing I've done.. then you can enjoy the 5.1 (or 4.1) sound better.....
Posted Wed 27 Feb 08 @ 7:00 am
I've got the same problem! so what sort of sound card do I need because I've been looking around ebay and can only seem to find cards described as Sound Card 5.1 Channel Adaptor's. I dont no if this will do the trick !? also i have vista and dont no if i'll be able to find a compatible card !
Posted Sun 09 Mar 08 @ 7:41 am
guys you may want to look here
http://www.virtualdj.com/forums/86839/PC_Version_Technical_Support/is_it_possible_to_do_this_.html
and here
http://www.virtualdj.com/blog/tayla/
hope they help
Tayla
and here
hope they help
Tayla
Posted Sun 09 Mar 08 @ 7:52 am
Hi Guys,
I choose mostly to plug in the set on a mixer which is already in the club... So my MK2 provides two outputs only.
The headphone is plugged in in the club's mixer and off we go ! ;-)
Posted Sun 09 Mar 08 @ 8:49 am
i almost always put them on over my ears ......however they can be used as a tres chic strapless bra ....
Posted Sun 09 Mar 08 @ 12:27 pm
hehe
Posted Sun 09 Mar 08 @ 12:57 pm
