I downloaded and installed the DJC Mapper for my MK2. Everything seems to work fine. I want to change the "Pitch Bend" buttons to work as a key changer instead. I have the button set as key_offset and left the buttons as the correct "relative" (either + or -). My only problem is that I cannot figure out the correct "Value" for one whole key up or down.
Anyone know this or tried it?
Thanks!
Tim Breckheimer
Phoenix, NY
Thanks!
Tim Breckheimer
Phoenix, NY
Posted Tue 26 Feb 08 @ 9:30 am
