Forum: Old versions
Topic: a problem with headphones and soundcard
the problem is as follows
when I try to set up my V Dj to play seperate on speakers and headphones I hear nothing on the headphones I just hear the both tables on my speakers the sound card is Creative SB live 5.1 and im using V dj 2
keep on mixing
Posted Fri 03 Dec 04 @ 2:19 am
An easy fix
First uninstall the cracked version, go to the homepage buy a copy of virtual dj, next download it, then contact e-service to unlock vdj (due to the crack being detected) Next enter the now working sound card config, by clicking on the tab marked soundcards. Click on the 4.1 and volia you've got headphones.
I am new to this program and I too can not get the headphones to work at all
When I first installed the program the headphone worked and when I rebooted the system it stoppped
I used the simple configuration and tried to play around with the advanced and still can not get it to work
help please
HEADPHONES DO NOT WORK IN THE DEMO VERSION
ahaaaa that's the trick how much dose the full version cost
