ok. i am a Quinceanera (sweet 16) choreographer here in Houston and i tend to give options as to what to dance. Most girls choose between 2-4 songs. I have to find a program that will help me mix these 2-4 songs fluently and be able to record them into a new trac to later burn in a cd to use on the day of the event. I currently have a copy of vitual DJ version 2.0 and it does the job but not to perfection. I also want the program to provide fade sound effects to make the mix a bit more interesting. Hope to get replies!!! Thank you
Posted Tue 12 Feb 08 @ 9:13 am
If your not going to be using the software at the event MixMiester Studio does a good job of production style mixes. There is a free trial you can download and run it through its paces. If you are going to use it at the event..stick with VDJ v5r7.
Posted Tue 12 Feb 08 @ 9:18 am
Lol, that's exactly what I was going to say! For easy-to-do pre-recorded mixes, mixmeister is the way to go. Maybe even the home version would do for you.
Virtual DJ is best for when you want to get creative on the spot, so you can mix in real time
Posted Tue 12 Feb 08 @ 10:23 am
