How in the world can you order macros? I'm trying to set a macro to skip beats and save a cue. But when I use the assigned keyboard button to perform the two actions, it saves the cue first, then skips the beats, but I would like the opposite order to occur. I have set macros that require an order in the past as well, and they have performed in the desired order. It isn't clear to me how I am able to order it opposite at times.
I tried combinations of setting each of the shortcuts in a separate order to create the same macro, but to no avail in this occurrence. How do you set the macro's order? Since macros are allowed, I'd assume there should be a way to order them. THANKS FOR THE HELP!
Posted Tue 12 Feb 08 @ 5:25 am
Sorry to bump this up, but is there no way to do this? If not, seems like a simple thing to try and include for the next release ;) ...well, that and being able to create a shortcut that simulates a mouse hold on the turntable with a keyboard button. Of course, a Hold shortcut is already possible, but if it can be a "Mouse_Hold", then moving the mouse on the touchpad would make it automatically scratch anywhere on the screen (allowing one to be nimble without touching the wheels on his/her table). Would do wonders for the default skin that has a very tiny turntable.
Thoughts?
Thoughts?
Posted Mon 18 Feb 08 @ 12:53 am
The shorcut macros are sorted chronologically when you assign it, meaning that whatever is assigned first is executed first. You can however change the order of the macro by re-organizing the shortcuts with the "up" and "down" buttons.
Posted Mon 18 Feb 08 @ 2:51 am
hey k_one, thanks for the advice. I did try setting the macro shortcuts chronologically, but it didn't work. I then also tried doing the up/down thing, and still didn't work. Give it a try yourself. Try setting something to jump back 4 beats and setting a cue. It will always set the cue first. Even if it was to Jump back for 4 beats and then loop. It always loops, then jumps back 4 beats. (does this with any number of beats)
Posted Tue 19 Feb 08 @ 12:48 pm
