Why does the message "The sound card is already in use by another application" keep poping out on me? I was screwing around with the "sound card" settings in "config" and then that happen. I was trying to get it to work with the headphones option, where u can hear both songs together before its actually mixed. It worked fine when i was using the "simple config" where i selected the speaker and the headphones picture tab. Then i went into the "advance config" and screwed it up. Now it wont work, i can't hear the mix before i switch it on the crossover. How can I fix this? Is there any "reset settings" button or something, i can just press to resest all settings? Okay, well thanks . . . .any help will be appreciated. . . oh yeah, and re-installing it wont help, it saves the settings or something . .thanks . . .
Posted Tue 30 Nov 04 @ 7:46 am
