Ok here is my set up and what i'm thinking.
Cue LE - Upgrading to full version in a couple of weeks
Numark Total Control
Numark DJIO
Pretty basic for now.
Now i'm thinking of adding 2 Numark CDX's. I was wondering what you guys think of these and if i could control VDJ with these tables/cdj. Will they work with the time code? Can i have all three devices hooked up and playing at the same time?(if yes, what mixer would you suggest? ie: 2, 3 or 4 channel? make/model?
Thanks for any feedback
Numark DJIO
Posted Tue 05 Feb 08 @ 6:33 pm
if you plan to use vdj alone and nothing else, then a 2 channel mixer is what you need.
other wise, i strongly suggest a 4 ch mixer. for use with other devices: cd player, ipod, etc.
suppose you want to browse random songs from your infinite source of music collection. with 4 channels, you can browse on ch 3 and leave ch 1 & 2 for vdj
here is my setup
ch1: vdj left
ch2: vdj right
ch3: pc audio (browse random music with winamp)
ch4: cd player (backup in case computer crash or if requested by host to play a cd)
as far as brand, any brand will do.. vdj has all of the effects a mixer could have built in.
behringer is at the bottom. pioneer is at the top. denon is in the middle. personally, i would go for the behringer. no point in spending all that money.
here is my setup
ch1: vdj left
ch2: vdj right
Posted Tue 05 Feb 08 @ 7:13 pm
Thanks for your responce KZ.
What do you think about the CDX's along with my Total control?
Posted Tue 05 Feb 08 @ 7:23 pm
I use VDJ with cdxs and tccds with a 4 channel mixer. I use 1 for my mics since I do karaoke, 2&3 for VDJ, and 4 for my ipod.
You shouldnt have any problems with the cdxs and tccds. Just make sure your pc is up to date with updates and drivers, especiall directx.
I did use my mk2 for a bit but I upgraded to a MAYA44 USB.
Posted Tue 05 Feb 08 @ 8:28 pm
You think i should get rid of the Total control?? or try and keep it in the mix????
Posted Tue 05 Feb 08 @ 8:39 pm
Bump...sorry I'm just almost ready to buy the CDX's.
Posted Wed 06 Feb 08 @ 2:24 pm
Anybody?
Posted Thu 07 Feb 08 @ 3:46 pm
I took my mk2 outta the mix but it use it for small gigs with only one CDX on TCCD's....
Posted Fri 08 Feb 08 @ 10:46 pm
numarks' cdx's are native controllers for vdj.
no need for tccd.
no need for tccd.
Posted Sat 09 Feb 08 @ 2:48 pm
no need for tccd.
no need for tccd.
iCDXs yes..CDX no....
Posted Sat 09 Feb 08 @ 3:07 pm
my bad,
Posted Sat 09 Feb 08 @ 5:56 pm
Thanks for the info.
Can anybody tell me how alike are the CDX's to real TT's?? Are they worth the $600/each price tag?? Or am i just wasting my time?
Thanks again.
Thanks again.
Posted Mon 11 Feb 08 @ 1:17 am
I have use my CDX's with Torq for a year and just start it using them with VDJ. I really love my CDX's as a matter of fact i got a good deal on some 1200's,but i have a heavy hand when it comes to scratching and juggling so went back to my CDX's. They're also very responsive with VDJ.
Posted Wed 13 Feb 08 @ 1:06 pm
Well after reading endlessly on the CDX's with all their problems and the possiblity of them being discontinued, i've decided to steer clear of them. And I am now going with the iCDX's.
Just trying to find out how to use my Total control and the iCDX's at the same time with VDJ. Also wondering how much functionality i will be losing on the TC. For exaple, i know the iCDX's do FX's and loops, will i still be able to these things on the TC? Or will it turn into a basic 2 channel mixer?
Posted Wed 13 Feb 08 @ 9:15 pm
Bump??
Posted Fri 15 Feb 08 @ 1:31 pm
