Hello.
Version 5.1 is almost ready, but in the meantime here is v5.0.7.
You can now link videos to audio-only songs (drag and drop the video on the skin's video preview window), you have a new button to log requests you couldn't fullfill (in order to download them once back home after the party), a new option to remember manual adjustments on gain, and a new karaoke plugin to manage your rotations and display various messages.
Plus some various minor bug fixes.
v5.0.7 is also available (and stable) on Mac.
Posted Sun 03 Feb 08 @ 9:21 pm
nice new features
i think there are some new pitch ranges, too
still trying to figure out about the log request function...
please give us some further details
thanx,
matt
thanx,
matt
Posted Sun 03 Feb 08 @ 10:03 pm
Good thing I put this on my tester laptop and not the live rig... http://www.virtualdj.com/forums/84955/PC_version_bugs_report/VDJ_5_0_7_Karaoke_Plugin_Failure.html
Update: solved by installing latest directx 9.0c runtime. Older directx 9.0c installs may need to be updated, however old and new versions still list as 9.0c under dxdiag.
Posted Mon 04 Feb 08 @ 12:22 am
does it fix the native support for Denon controllers(dh-hc4500, dn-hs5500)?
Posted Mon 04 Feb 08 @ 12:55 am
No, the denon is not fixed yet (need fix from Denons side)
Posted Mon 04 Feb 08 @ 1:24 am
Here a summary list
New features:
- added +-100% pitchrange in options, action "pitch_range", item "%pitchrange" in skin textzones
- new ASIO engine (default engine is when "ASIO UltraLatency" is checked, new engine is unchecked and is safer)
- new button to log searches, so you can download after the party the requests you couldn't find
- new auto-gain options (auto+remember, remember, auto, disabled)
- can drag a video file on the video preview window to link with audio-only files
- option in video config to disable link on drop
- actions "Video_Link", "Video_Unlink", browser column "LinkedVideo", search option "LinkedVideo", filter items "LinkedVideo", "HasLinkedVideo".
- can now unlink video by drag&droping the original file (in addition to context menu option still present)
- added "%linkedvideo" in skin textzones
- skin slider "round" are automatically rotated if doesn't have . in this case, optional param "minangle", "maxangle" can specify the rotation angles at 0 and 4096 in degree.
- new skin object , new actions "multibutton", "multibutton_select"
- clipbank plugin can be cloned (clipbank2.dll, etc)
- new karaoke plugin
- compatible with new Hercules DJConsoles (mobile, Rmx)
Fix:
- fixed itunes songs with "&" character
- fixed accents in itunes folders
- fixed pitch/bpm for HC4500
- fixed some minor bugs
If someone have problem with Karaoke plugin please Download DirectX End-User Runtimes (November 2007)
http://www.microsoft.com/downloads/details.aspx?displaylang=en&FamilyID=1a2393c0-1b2f-428e-bd79-02df977d17b8
New features:
Fix:
Posted Mon 04 Feb 08 @ 2:21 am
what is this? ->
Posted Mon 04 Feb 08 @ 2:36 am
I see it is compatible with new the new Herc RMX DJ Console, great. Will it be a matter of just plug and play ( native support ) when the console gets released.
Jimmy b
Jimmy b
Posted Mon 04 Feb 08 @ 3:22 am
Yes Jimmy, new Hercules RMX will have native full support, just only to plug and mix ;)
Posted Mon 04 Feb 08 @ 3:50 am
Cool Cioce, and thanks :)
Jimmy b
Jimmy b
Posted Mon 04 Feb 08 @ 4:07 am
appreciate the hard work guys!
Posted Mon 04 Feb 08 @ 5:11 am
What a good little feature, just noticed the button. I had a couple of requests for tracks on Friday night, which I didn't have, Had to write them down on a scrap piece of paper, to grab when I got home, so unprofessional, but with this neat feature it does away with that. Nice
Jimmy b
Posted Mon 04 Feb 08 @ 5:31 am
Is the DAC-2 bug fixed?
Posted Mon 04 Feb 08 @ 6:20 am
Thanks guys ,will update tonight.
Any chance of Napster being able to connect coming anytime soon?
Posted Mon 04 Feb 08 @ 6:22 am
Yes the DAC-2 Bug is Fixed !
Posted Mon 04 Feb 08 @ 6:29 am
VanStino is heading to the download center.
Posted Mon 04 Feb 08 @ 6:30 am
Just be carefull with the current DMC2 mapper of jpboggis and pitch=-100%, you could have a crash. But I guess the mapper will be fixed soon by him
Posted Mon 04 Feb 08 @ 7:04 am
Thanks for this update! cred to the team involved.
Seems to work ok for me.
Posted Mon 04 Feb 08 @ 8:13 am
good work team... tequila-espresso martini's all around
Posted Mon 04 Feb 08 @ 9:26 am
be careful when going to -100% with the dac3 and boggis mapper too! it'll crash!!!!
Posted Mon 04 Feb 08 @ 11:24 am
