I am having trouble searching within the comments field with 5rev 6. I just switched from version 4 where I had no problems. Search will not find any comment in the tags. I did not have this problem in previous version and I use this search function frequently. Is there something I need to to enable or do? The search tags function is enabled in the settings.
Please help.
Bless
Please help.
Bless
Posted Fri 25 Jan 08 @ 12:46 pm
To the right of the search field, click on the first 'bullseye' dot, and select the comment field as a search field. Also, you may want to select the Filepath and Filename as searchable fields. Also, if you recently switched, please go through the manual; it is thorough in a lot of the changes from 4 to 5 - Searching being one of them.
Posted Fri 25 Jan 08 @ 1:52 pm
Thanks Cstoll,
I guess I am guilty of not reading the manual. Problem solved.
Thanks again.
Bless
Thanks again.
Bless
Posted Fri 25 Jan 08 @ 2:20 pm
