Sup ya'll,
I wanted to buy the M-Audio UC33e which I have seen a lot of dj's especially those that come from europe use with ableton live and they have rocked out the room dirty style. Can and will vdj work with M-Audio UC33e and a pc computer only? I'm trying to get away from the decks to go into a different direction here. Easier to carry and go places.
Thanks,
Darwin
Thanks,
Darwin
Posted Thu 24 Jan 08 @ 8:15 am
The UC33e will work with VDJ as it's only a midi device, but honestly, in my opinion that controller won't be of much use for VDJ control. Sliders are a good thing to have, but when used in Ableton, they control different channel's volume, and the knobs would only be used for the Effects in VDJ.
What may interest you more is another one of M-Audio's products, the "X-Session Pro"
http://www.maudio.co.uk/products/en_gb/XSessionPro-main.html - X-Session Pro
or the Torq Exponent, but it's a little bit pricey.
Posted Thu 24 Jan 08 @ 2:15 pm
You should also check out the Vestax VCI-100. I've been using it for a while now and it's great to just bring it with your laptop and sound card.
Posted Thu 24 Jan 08 @ 4:49 pm
