can it be done?
Is the MK2 console native USB 2.0?
Posted Wed 23 Jan 08 @ 2:52 pm
It is possible , http://www.virtualdj.com/forums/58120/Hardware_Technical_Support/Guide_To_set_up_tcv_with_mk2_console__)_.html
As the the 2.0 it can work on 1.1 or 2.0 fine , you may find however the Hercules drivers are quite bloaty you may have better results with asio for all.
http://www.virtualdj.com/forums/68291/Hardware_Technical_Support/Some_general_info_about_Hercules_DJ_Console_MK2.html
Posted Wed 23 Jan 08 @ 4:01 pm
