I bought today my dj console mk2 and i cant get it to work. I install everything as orderd, new patch etc
Now when i plug in the dj console, the play/pauze and cue button are lighted all the time, stuck? freeze?
I looked everywhere (googled etc) or maybe over saw it , o well if anyone has a solution for this problem...... tnx
Posted Mon 21 Jan 08 @ 5:51 pm
First, you might want to try uninstalling and reinstalling the Hercules driver/software package. If that doesn't work, you may need to reset the console.
Here is a procedure from skyfxl:
Be sure and send him a "thank you" if the reset procedure works, k? I'll be checking in from time to time to see if you have questions.
Doc
skyfxl wrote :
Here is what you need to do if your controller dies (controller part, and not the soundcard) :
1) Kill the HDJ2CPL.exe in taskmanager.
2) Click Start, Run and type in "c:/Program Files/HerculesAudioDJ
Console Series/Mk2updater/hdj2updater.exe" -manual and click OK. (slashes other way, but the forum don't allow them). This opens up a flash tool for the firmware on the console.
3) Hold effect button 1 + 2 + 3 at the LEFT deck pressed down at the same time, and KEEP them pressed while you reconnect the usb cord to the console.
4) The firmware flash window should show "boot" for firmware controller if sucsessfull.
5) Press the Ctrl button at lower end, and choose the file "HDJ_PSOC1.djc"
6) Make sure there is a check mark in the Flash for the Firmware controller and press update!
if the Sound Section Fails
1- Disconnect the Console.
2- Shutdown the system. (Restart will not do, make sure to completely
shut it down)
3- Turn it back on.
4- Once completely restarted, close the MK2 mixer on the taskbar. If it
isn't there click Start, Run, type in taskmgr then click ok. Go on the
Processes tab and locate the HDJ2CPL.exe right-click it and choose end
process then click Yes on the warning message.
5- Click Start, Run and type in "c:Program FilesHerculesAudioDJ
Console SeriesMk2updaterhdj2updater.exe" -manual and click OK.
6- Hold talkover button on the console and reconnect it (make sure to
hold the button while plugging it back)
7- Now the DJ Console Mk2 Updater Firmware Controller should say boot.
Click the Open Ctrl... button and select HDJ_TUSB.dja file then click
Open..
8- Make sure there is a check mark in the Flash for the Firmware
9- Unplug the DJ Console and plug it back.
10- Check in the DJ Console Updater if a firmware is now installed.
11- Go in the Control Panel and then into Game controllers.
12- Go into the DJ Console Mk2 properties and move the treble knob on
the right side of the console. If it works your good to go, if it
doesn't repeat the procedure from section 7.
IF update fails
a)tell support at herc, the error code.
b) check to see if buttons and axes respond in the game controller
properties
c) make sure that no LEDs remain lit when the device is plugged
d) check the DJ SDK DLL version (system32hdjsapi.dll)
shut it down)
3- Turn it back on.
Open..
IF update fails
properties
Doc
Posted Thu 24 Jan 08 @ 2:39 am
worth noting that step 5 is missing backslahes
Posted Thu 24 Jan 08 @ 6:47 am
Indeed. Thanks Paz ;)
Posted Thu 24 Jan 08 @ 10:49 am
