Hello there Fellow Dj/Vj's. I'm using Cue need help with getting video to upload. I have the audio but no video in main monitor or A or B monitor can anyone help me with this problem? Thanks
Posted Fri 18 Jan 08 @ 8:31 pm
Make sure that video is "enabled (button on top)" and "activated(check box)" on the video tab in config. That should do it. If not, post back with the video file format you are trying to use, as well as your system specs, including video card.
Posted Fri 18 Jan 08 @ 8:43 pm
