Ok I have two internal sound cards in my desktop computer
one is for DJing and one is for everyday computer work. VDJ
will not keep the one I save in the setup. Is there a way to take
one out of setup all together?
Thank you
Thank you
Posted Thu 17 Jan 08 @ 7:48 pm
Can anyone help with this?
Posted Fri 18 Jan 08 @ 11:06 am
You could disable it in control panel/sounds and audio devices, or device manager. There may be something else going on, as this should not be a problem. I do not have this problem on any of my machines.
Posted Fri 18 Jan 08 @ 1:55 pm
If I disable one in the control panel i can't use it I need both to work.
Posted Fri 18 Jan 08 @ 4:30 pm
I thought that is what you wanted to do. What OS are you using, and which card does not save?
Posted Fri 18 Jan 08 @ 4:46 pm
I have xp and I use my audigy 2 for VDJ and my xtreme 5.1 for my default sound card for xp.
I would setup the audigy 2 sound card for VDJ but it will change sometime (i out 3 times). Is
there a way that I can make VDJ only see my audigy 2 card?
Posted Fri 18 Jan 08 @ 5:55 pm
