how do you use a regular vinyl record if your setup for TCV? I assume you can't just put a record on and it will start playing..right?
Posted Sun 13 Jan 08 @ 2:59 pm
yes it does you will just have to assign a key for the bypass function. i think it is timecode_bypass.
Posted Sun 13 Jan 08 @ 3:07 pm
a feature they removed ages ago, dont think its come back has it?
besides the quality doing it that was is dire, what you need is a soundcard with passthrus or some switches / splitters
Posted Mon 14 Jan 08 @ 7:49 pm
timecode_bypass is still there...
Posted Mon 14 Jan 08 @ 8:49 pm
Do i have to have rca splitters from the turntable so my turntables are connected to my sound card AND my mixer?? where is this timecode bypass?
Posted Tue 15 Jan 08 @ 4:25 pm
These are the 2 options.
Either have the RCA splitters like you described.
OR
you can use the by-pass option. It is in the selection of shortcut options that you can program to a key on your kyeboard. The by-pass option does not require the rca splitter. It will work from your current set-up.
OR
Posted Wed 16 Jan 08 @ 7:22 am
