What are you guys using to mount your flat panels to truss or stands? Links please.
Posted Tue 08 Jan 08 @ 3:44 pm
I made mine.
Posted Tue 08 Jan 08 @ 4:31 pm
Who's next?
Posted Wed 09 Jan 08 @ 3:05 am
here you can get some ideas
http://www.smartmediasolutions.se/en/
Posted Wed 09 Jan 08 @ 4:55 am
I used two of these :-
http://cgi.ebay.co.uk/LCD-TV-TFT-SCREEN-DESK-MOUNT-BRACKET-TILT-SWIVEL_W0QQitemZ200114410927QQcategoryZ122652QQcmdZViewItemQQisPrinterFriendlyZ1QQpvZ2
All the joints come apart and you can add a truss bracket etc to one of the joints, the whole stand is like a meccano kit so is VERY adaptable, highly recommended.
Posted Wed 09 Jan 08 @ 5:58 am
@ TopHouse, I'm talking about 37' LCD TV monitors. Sorry guys if I did not make myself clear. Weighs about 42 pounds.
Posted Wed 09 Jan 08 @ 1:34 pm
amahm
you may have to re fabricate a standard lcd wall bracket to suit your needs, get two u exhausts brackets per screen, drill holes to suit u bracket on wall mount bracket, tighten round pole with butterfly nuts, hope you understand what i mean
thats if there not already manufactured
Tayla
Tayla
Posted Wed 09 Jan 08 @ 3:09 pm
I used this wall mount from target and clamps from sam ash. The support a 32" Olevia LCD and is mounted on a standard light stand.
http://www.target.com/Wall-Mount-Panel-Black-LCD60B-01/dp/B0006I4RAU/sr=1-17/qid=1199945903/ref=sr_1_17/602-7958604-5879851?ie=UTF8&index=target&rh=k%3Atv%20mount&page=1
http://www.samash.com/catalog/showitem.asp?ItemPos=1&TempID=2&STRID=11949&Method=2&CategoryID=0&BrandID=0&PriceRangeID=0&PageNum=0&DepartmentID=0&pagesize=10&SortMethod=3&SearchPhrase=clamps&Contains=%2Aclamp%2A&Search_Type=SEARCH&GroupCode=
Posted Thu 10 Jan 08 @ 12:20 am
Thanks Guys, I ordered 2 of these.
Posted Thu 10 Jan 08 @ 2:27 am
