I haven't uploaded it yet ;)
Posted Fri 20 Mar 09 @ 11:44 am
I've uploaded an updated mapper v1.32. It will be available for download once approved. This will be the last release of this mapper.
Posted Tue 07 Apr 09 @ 9:48 am
Now available ;)
http://www.virtualdj.com/addons/4091/M-Audio_Xponent_Mapper.html
Posted Tue 07 Apr 09 @ 3:15 pm
Good to hear, mate. Thanks once again, Scotty.
Posted Tue 07 Apr 09 @ 3:16 pm
thanks 4 the new release, i test it this weeknd.
everything was perfect in the PC Side
But In The Mac Side, it stuck once and i have to restard VDJ,
Posted Sun 12 Apr 09 @ 10:04 pm
can i still using this mapper after install VDJ 6?, I Didnt install it yet 'till im sure this is posible. . . .
Posted Mon 01 Jun 09 @ 1:44 pm
Mapper technology has been completely rewritten; thats why I said before that the current version was the last - dll mappers are no longer needed, you map with VDJScript now :)
Posted Mon 01 Jun 09 @ 7:39 pm
i see, but can you help us to configure our xponets the way it work whit your mapper but using the new scripts,
ej. what command should i use to set the cue buttons like they work now??, they are a mix of 2 scripts" hot_cues", and "cue_select"
Posted Mon 01 Jun 09 @ 8:10 pm
I can try and port it to v6 VDJScript if you like...
Posted Tue 02 Jun 09 @ 5:44 am
that would be so nice and helpfull cuz i can have it working right and learn the new way to mapp in VDJ6,
Thank For The Help!
Thank For The Help!
Posted Tue 02 Jun 09 @ 11:18 am
ok, i started from scratch to mapp and its so easy now but i have some issues, this is what ive done so far
<?xml version="1.0" encoding="UTF-8"?>
<mapper device="XPONENT" author="Atomix Productions" description="MAudio XPonent" version="600" date="02/06/2009">
<map value="FINGER" action="vinyl_mode" />
<map value="GAIN" action="power_gain" />
<map value="GAIN_MATCH" action="match_gain" />
<map value="HIGH" action="eq_high" />
<map value="KILL_HIGH" action="eq_kill_high" />
<map value="MID" action="eq_mid" />
<map value="KILL_MID" action="eq_kill_mid" />
<map value="LOW" action="eq_low" />
<map value="KILL_LOW" action="eq_kill_low" />
<map value="PLAY" action="play_pause" />
<map value="CUE" action="cue_play" />
<map value="JOG" action="scratch_wheel" />
<map value="CUE1" action="hot_cue 1" />
<map value="CUE2" action="hot_cue 2" />
<map value="CUE3" action="hot_cue 3" />
<map value="CUE4" action="hot_cue 4" />
<map value="CUE5" action="hot_cue 5" />
<map value="PITCHBEND-" action="pitch_bend -3" />
<map value="PITCHBEND+" action="pitch_bend +3" />
<map value="LOOP1" action="loop 1" />
<map value="LOOP2" action="loop 2" />
<map value="LOOP4" action="loop 4" />
<map value="LOOP8" action="loop 8" />
<map value="RELOOP" action="reloop_exit" />
<map value="LOOPIN" action="loop_in" />
<map value="LOOPOUT" action="loop_out" />
<map value="PITCH" action="pitch" />
<map value="VUEMETER" action="get level" />
<map value="SYNC" action="sync" />
<map value="PROGRESS" action="get position" />
<map value="VOLUME" action="volume" />
<map value="CROSSFADER" action="crossfader" />
<map value="PFL_MIX" action="headphone_mix" />
<map value="X" action="browser_enter" />
<map value="LOOP+" action="browser_scroll -1" />
<map value="LOOP-" action="browser_scroll +1" />
<map value="LOOPLOCK" action="master_tempo" />
<map value="HEADPHONE" action="select" />
<map value="LOOPSHIFT-" action="browser_window -1" />
<map value="LOOPSHIFT+" action="browser_window +1" />
<map value="TRACK+" action="seek +4" />
<map value="TRACK-" action="seek -4" />
<map value="FX1_KNOB" action="sampler volume" />
<map value="FX1" action="sampler play_stop" />
<map value="FX2_KNOB" action="effect slider 1" />
<map value="FX3_KNOB" action="effect slider 2" />
<map value="FX4_KNOB" action="effect slider 3" />
<map value="FX2" action="effect active" />
<map value="FX3" action="effect select -1" />
<map value="FX4" action="effect select +1" />
</mapper>
1.- now, how can i set up the shift button to make a different layout?. ej Shit + loop 1 = 16 Loop
2.- if i want to set up the touch panel for video effect only how i do this? ej. i want the left/right buttoms for Video FX Select, touch to activate , and X/Y Video FX Sliders
3.- the power gain is from -30db to +30db, can i adjust this to make from -20db to +15db?
4.-the jog is too xtreme how can i slow down the sensibility?
5.-how can i make up the leds?, ej01; i want the active hot cue blink to know wich one is active, ej02; i want the progress blinks the last 30 secs
ej03.- i want the finger leds work like you mapper (bliks when active and blik faster whit touch the center of the jog)
6.- where are the X-mas mode
hope you can help me to understand the more complex xpresion on this new feature
</mapper>
Posted Tue 02 Jun 09 @ 4:11 pm
SBDJ v6 VDJScript would be nice but first i need to get my xponent to work right on v6 any of
you all having problems? I can not close vdj right if my xponent on in running. if its not on all is good.
I was told that it's a problem with the release of the controller in MIDI.
Posted Wed 03 Jun 09 @ 2:07 am
Hi Scott , well there i was thinking it was all over and very pleased to have your mapper and then they went and started using scripts....;-/
I have no idea what would be involved to convert your 1,32 mapper , if it would be a five minute thing or a long thing.... I guess one of the team may do it.
Please let us know if you decide to convert etc....Hope all is well with your family , Cheers Paul
Posted Thu 04 Jun 09 @ 12:09 am
i just test this last night in a gig and work fine exep for the little inconvenience described in the point 1,3,4,
i been working for 2 days now and every work fine n better so far . . .
audio000 wrote :
i need to get my xponent to work right on v6 any of you all having problems?
Posted Thu 04 Jun 09 @ 10:30 am
Alf Elias
1. What is your OS
my OS = Vista 32 bit sp2
2. what is your V of VDJ
my V of VDJ = 6.0.1
3. What drivers do you have for the Xponent
my drivers = 5.10.00.5112 firmware 1.0.0
I am not the only one that is having problems
http://www.virtualdj.com/forums/109808/General_Discussion/V6_take_a_long_time_to_close.html
If you are up and running let me know what you did bro thanks
P.S
Yes it does work but can you close VDJ (The Right Way and Keep all Your Setting) after its up and running with your Xponent on
1. What is your OS
my V of VDJ = 6.0.1
P.S
Posted Thu 04 Jun 09 @ 12:34 pm
Hi audio000
Im Using XP, and im using the xp driver not the vista one i use it since long time now, and using VDJ 6.0, ill install 6.0.1 2nite ill let you now how it works!
i didnt do anything special just install VDJ 6.0 and mapp the xponent thats all i did. . . . if you need to know something about my PC let me know. . .
and if any one can help me improve my mapp as i describe in my early post any help are welcome!!!
Posted Thu 04 Jun 09 @ 5:27 pm
Yes you are right about xp working but not vista my friend but it did in V5
Posted Thu 04 Jun 09 @ 6:24 pm
Just to let you know I've kind of ported my code across to v6. It's not exactly the same, I've kind of merged their default mapping and mine to create on that is largely similar but with a few important differences.
I'm open to feedback, but remember that you can change the mappings yourself easily anyway ;)
As usual it will be available once approved by the web team.
Posted Mon 15 Jun 09 @ 11:54 am
SBDJ
This is good news bro thanks again
did you get the xponent to work right with Vista 32bit (close VDJ Right)...?
Or is this for xp only...?
Posted Mon 15 Jun 09 @ 9:14 pm
Hi Scott , great stuff , thanks for the mapper , really appreciate it , will try it out tomorrow night , all the best , Paul
Posted Tue 16 Jun 09 @ 12:16 am
