Forum: Old versions
Topic: SECRET SHORTCUTS FOR PREVIEW PLAYER HELP
djlexPRO InfinityMember since 2004
Is there any keyboard shortcut to close the preview player?
I can open the preview player with ctrl+enter then it does pause play with the space bar.
Once the preview player is on, you can switch focus between the preview player and the vdj with alt +f6, but I culdn't find any way to close the preview player without using the the mouse
Also if I press alt+spacebar a dialog window is poping up in the left upper corner which wants to close vdj if you press alt+f4, is any way to dissable this unwanted effect ?
BTW I wonder if they are any other secret shortcuts that are not in the shorcut list
Posted Sat 29 Dec 07 @ 5:03 am
he he , found it alt+f4 does close the preview player, just be carefull if you do it twice , vdj is closing just as fast,
also alt+space opens a pop up window that gives you two options to move the preview player or to close it, you can use up and down to highlight and enter to select
Posted Sat 29 Dec 07 @ 5:23 am
