Topic: Numark Total controller HELP!!!!
I would like to change sound effect controls to control the video effects or video transitions on my Numark Total controller.
I us the Fkeys for controlling the sound effects, unfortunately no one has made a mapper yet for the NTC.
Is there a way I can make this happen without a mapper?
Posted Wed 26 Dec 07 @ 4:29 pm
you could map the console manualy :) via the midi mapping section on
remote controls > midi
That would be great. Could you please give me the detail instructions on this? I heard of this but just to computer illiterate to figure it out.
Thanks
Previous to R4
Rev + 4 and 6
go to remotes > and enable general midi and right click and press options, and press add
You will now see a list of possible actions for each button or slider , each option is explained on screen.
Repeat these steps until , the console is mapped to your liking ,you may also find this link helpful it is a midi number list for each button.
http://www.numark.com/stuff/contentmgr/files/9e0e1954f2b6a7df5d19e96a4994163a/file/totalcontrol_midimap.pdf
Thanks skyfxl. You always have the answer.
I ‘ll check it out in the AM. I’ll get back to you on my results.
The link this.
Total Control are permanently set and not
adjustable.
Dose this mean that the controler can't be re-mapped?
That means you cant change the midi numbers some applications have a preset list of what notes should do and this is not changeable .
However as vdj works on assigning an action to a midi number this isn't a problem
as you can set any action to that one number in vdj options.
thank.
I quickly attempted to change the effect to video but nothing seemed to happen but will spend some time after my gig tonight.
thanks
