i have installed all the software and every time i try to boot up the actual virtual vinyl i get a pop up sayin this is a trial go to this swebsite to order
its doin me head in
someone help
i dno wot to do
its a genuine version and it doesnt work
helppp!!!!!!
its doin me head in
someone help
i dno wot to do
helppp!!!!!!
Posted Wed 26 Dec 07 @ 8:46 am
Check if you have the latest 5.0 rev6 version here http://www.virtualdj.com/update.html
Posted Wed 26 Dec 07 @ 9:03 am
Hello there,
1) What you need to do is make sure you have a FULL install of the latest program, keep that safe.
2) Completely uninstall Virtual DJ, VDJ Demo, Home, Numark Cue Demo, Virtual Vinyl or whatever related programs you have installed.
3) Restart your computer and install the program again, VDJ should now start up fine.
Posted Wed 26 Dec 07 @ 9:37 am
If after following those suggested steps still no joy ,uninstall then download and run the Registry Clearing tool.
http://www.virtualdj.com/addons/tools.html
If then no joy contact support.
Posted Wed 26 Dec 07 @ 3:07 pm
