When I record the setting it saves the .wav's on is 1,141kps ?? the files are way to huge to do anything with. One song is like 100mb's ? How do I change this ??
THANKS GUYS !!!!!!!!!!
Posted Fri 19 Nov 04 @ 11:38 pm
That is of course talking about the normal record setting in Virtual DJ and not using anything else.
I have no idea why it saves this large and can't find the pace to change it.
If i can't do anything can anyone reccomend a good compressing program ?
Posted Fri 19 Nov 04 @ 11:45 pm
VDJ typically saves to MP3's. When you type the file name to save as see if you can select MP3 vs. Wav (below where you would type the name of the file you're saving.
I haven't come across this problem but you may want to try that. VDJ has been perfect recording for me.
Also, I hear if you have a cracked version many strange things happen.
Posted Tue 23 Nov 04 @ 8:29 pm
