I have to press every key on the unit 2 times in order for it to activate anything. Like if I want to play, I have to press Play on the BCD 2 times. but Cue works instandly. Please help solving this issue. Any help would be great.
Posted Mon 17 Dec 07 @ 3:21 pm
you might get a quicker response if you post this in the hardware forum
Posted Mon 17 Dec 07 @ 4:57 pm
And more helpful info if you where to ...
1. Search the forums.
2. Purchase the software so you can download mappers that are available.
3. NOT Double and Triple post your question.
Posted Mon 17 Dec 07 @ 5:20 pm
buy vdj and use standard in the bcd2000 control panel
Posted Tue 18 Dec 07 @ 1:45 am
I did purschase vdj but never had time to waste my time regestring on the forum with it because of dumb people like you responding like you have. I asked a simple questions and in return I get this BS. You guys are no help what so ever.!
Posted Tue 18 Dec 07 @ 9:52 am
then please kindly add your serial number , and take your place amoungst the elite of vdj
you will find insulting people who want to help you isnt the best path of action
Posted Tue 18 Dec 07 @ 10:30 am
ppajko wrote :
I did purschase vdj but never had time to waste my time regestring on the forum with it!
It will just took a minute of ur time or less... it not time wasted at all. N Pls be mindful about the language. Thanks
Happy holidays.
Posted Tue 18 Dec 07 @ 10:57 pm
i did help u if look what said to click the stanard in the bcd2000 controller panal ,and cut your bs next time u will not get help.thank you!
Posted Tue 18 Dec 07 @ 11:31 pm
