Use a notebook ASUS G2S and hercules MK2. Sometimes the sound cuts and then back. Yesterday I made a presentation and sound failed some 10 times. How to fix this problem?
Posted Tue 11 Dec 07 @ 6:30 am
More info please. Explain cuts and then back. More machine specs, and are you using video?
Posted Tue 11 Dec 07 @ 1:55 pm
Thanks for response. The sound and some back quickly. Sometimes the computer hangs and I have to restart the machine. The sound for all. I have 2 notebook ASUS G2S and two Hercules MK2, the problem happens in all equipment. On a windows have views and it is only installed the Virtual DJ, nonetheless gives problem. Work only with videos. We use only sounds. If I leave the VJ running alone, automatically, it also locks after a while.
Now the problem happened several times and the track stopped. It's terrible.
Its address?
Thanks
Its address?
Thanks
Posted Fri 14 Dec 07 @ 4:54 am
In the settings of the console (not vdj !), you need to set the buffer higher!
Posted Fri 14 Dec 07 @ 6:47 am
Not understood. You say I have qu configure the MK2? But he has no settings of "buffer" or have? Why is the sound failure?
Posted Fri 14 Dec 07 @ 8:20 am
Is the mk2 with soundcard inside ? If no, I´m sorry, I was wrong.
Posted Fri 14 Dec 07 @ 8:34 am
i am sorry, went in the config of MK2 and really, in the flap, MAIN, is the "ASIO BUFFER SIZE" and is marked N / A. What is the correct way to set?
Posted Fri 14 Dec 07 @ 9:49 am
If you have the mk2, click on the Asio button, that should bring up the Asio Buffer size options. I have mine on about 2606 I think, try that.
Jimmy b
Posted Fri 14 Dec 07 @ 10:04 am
