My equipment: DAC-2, Denon DN-X900 Mixer, Maya 44USB. VDJ 4.x
The problems: I want to use the on-board sound card for the samples, but I have run into a problem. I configure the Maya for the left and right deck (Channels 1, 2, 3, 4), controlled by the DAC-2 and the samples use the the on-board card. First, I can only guess what the settings are because the drop-down menu cuts off the sample setting, so I only see, for example, left deck: channels 1&2; right deck: channels 3&4 and that's it. Now, all seems well as I am able to hear the sample through a 3rd channel on my mixer. The second problem is that the left deck plays and sounds normal, but I get no output from my right deck when using this configuration. I'd like to get the first issue resolved, so that I can be 100% sure what the entire sound layout is. Maybe I have something configured wrong, but can't see it to fix it. Thanks.
Posted Mon 10 Dec 07 @ 1:52 am
