Forum: Old versions
Topic: Numark Total Control Problems And Questions - Page: 5
Posted Fri 17 Dec 10 @ 2:26 pm
wfwr915Home userMember since 2011
Can't seem to get full screen video. Only see mixer video. Everything else works
Posted Fri 24 Jun 11 @ 10:12 am
Sorry, full screen video is only possible in the full VirtualDJ Professional: http://www.virtualdj.com/buy/index.html
All other versions including Home FREE are limited to a small video output window only.
Posted Fri 24 Jun 11 @ 12:59 pm
hi, is anyone else having problems with the hurcules 4Mx, half way through the night the jog wheel stops working as it should and starts controling the playlist area, so then i cant use it to line up the beats unless i restart the computer. Any Ideas ?? thanks
Posted Thu 28 Jul 11 @ 1:18 pm
By default, the jogwheel will browse songs when you hold down the headphone pre-listen buttons or the up/down button.
It may be that this has not released for some reason, or maybe you have customised the mapping so that these do not function correctly any more.
To disengage the browsing, either press and release one of the above buttons or map a button or keyboard shortcut of your choice to the following:
deck left wheel_mode "jog" & deck right wheel_mode "jog"
For basic mapping instructions, please see http://www.virtualdj.com/homepage/jpboggis/blogs/4149/VDJscript_Mapping.html
Posted Fri 29 Jul 11 @ 6:32 am
nsanleHome userMember since 2012
i can't use my numark total control with the virtual pro 8
Posted Thu 15 May 14 @ 12:55 pm
Posted Thu 15 May 14 @ 1:27 pm
