If you have installed vdj 5.0.6 with a BCD 2000 and The 3.2 Mapper and your pitch fader on the console is inoperatrive.
1/ Check that you select BCD 2000 as sound card in Sound Settings as shown in BCD 3.2 Mapper documentation
2/ Set the Pitch Range at 34% value in the general Option Panel in the settings.
Otherwise install back the vdj 5.0.5 version (I fall back to this version and check it works fine one more time).
I don't know about the BCD 3000 and older version of the mapper.
I suspect a mapper problem because on the new revision, new pitch range are introduced. And when come back to 5.0.5 it works and to finish when picth range is 34% it is ok. Otherwise, when you change the pitch with mouse it's ok.
You have the full bug description here => Here
I'll warm Moramax about this. Hope it will be simple to fix.
Posted Wed 05 Dec 07 @ 7:50 pm
The problem is fixed in BCD 2000 Mapper 3.3 thanks to Moramax outstanding work.
Posted Fri 14 Dec 07 @ 8:02 am
