I use VDJ5 REV5 on PC and VDJ5 BETA3 on mac also.
for years i use the naming convention "artists-track number-track title" without any tagging info.
As far as i can remember VDJ 4.3 was able to display only the filename to avoid issues with tag.
VDJ5 hasn't gor this feature and it's very painfull since it assumes that all the tagging is perfect !!!
Moreover, even if iTunes is perfectly tag and displays the correct information VDJ5 does not.
Can i display in vdj the full filename without any tag infos ?
Regards
Regards
Posted Wed 05 Dec 07 @ 4:13 am
Please look at the manual installed in your My Documents -> VirtualDJ folder -- a lot of info there.
The quick answer is to add Filepath and Filename to your searchable fields. Click on the 1st radio button to the right of the search box and select those two entries from the pop-up list. Also, updating to Version5 Rev6 fixes a Search bug similar to what you describe.
Also, if you right click on a column title you can see all the columns that you can view.
** All of this info is in greater detail in the manual. **
Posted Wed 05 Dec 07 @ 2:45 pm
Thank you for your help, i will carefully read the manual and come back here after gurther investigations.
Regards
Regards
Posted Thu 06 Dec 07 @ 2:45 am
not satisfied with this workarround !
Try this :
Purchase a CD, Import it with iTunes, let VDJ discover it (tag enabled, track/artist enabled, or not), the issue is always the same, if you have an "&" in the filename you're damned caught !!! VDJ will not play it
Regards
Try this :
Regards
Posted Sun 09 Dec 07 @ 6:42 am
