Forum: Old versions
Topic: need some help
f_dipPRO InfinityMember since 2006
is there anyway that i could use the hercules soundcard,so i could use the timecodes cd.i just bought two denon s3500
thanks in advance
Posted Mon 03 Dec 07 @ 1:13 pm
sbangsPRO InfinityMember since 2004
Posted Sat 22 Dec 07 @ 6:23 pm
f dip i would also recommend getting the asio4all driver to set up your denons,
so make sure to google "asio4all" then when you find the page download the beta 2.8
once you do that, open the settings up, disable the internal soundcard, then enable the herc, and start from the top latency buffer and slowly lower the fader setting until you reach the settings that allows you to play and mix without hearing any pops or clicks or jittery watery sounds,
let me know how it goes for you,
JC
Posted Tue 25 Dec 07 @ 12:09 am
Posted Tue 25 Dec 07 @ 6:00 am
