Ok. so i did djed a party 2 nights ago and was using tccd's. for some reason i kept on losing signal on the cd and i would have to play strait odd the laptop. the only way to regain signal was to switch the option from external mixer to 3lines mixer but it interrupted the song everytime i did that. it happened so many times to me that nite that it got to the point where i djed strait off the laptop cuz it was extremely annoying to me and to my crowd everytime i had to try to fix the signal. what can i do to have this problem fixed. the same thing happens to me when i use turntables. is it that my software is mest up or is it something im doing to cause this. SOME1 PLEASE HELP!!!...
Posted Sun 02 Dec 07 @ 7:01 am
I had similar issues last night. I'm using tccd and after awhile I would lose the signal or control on one deck and then a little latter on both decks. I had to restart the program to regain control but after awhile I lost control again and had to play using PC only. I'm using vdj 5.5 with Denon dns5000 cd player.
Posted Sun 02 Dec 07 @ 12:19 pm
im using the pioneer cdj1000 mk3 and virtual vinyl.. .something needs to be done it happens frequently and apparently im not the only one who has the problem
Posted Sun 02 Dec 07 @ 12:26 pm
so no 1 has n e suggestions?!!
Posted Mon 03 Dec 07 @ 9:34 pm
Same thing happens to me. I also get studdering sound, and if I keep playing through this pain, I eventually get ASIO errors on both decks. It is really irritating. I am using TCCDs with herc mk2 controller with config preset for fastest response. n e 1?
Posted Tue 04 Dec 07 @ 12:34 am
Can we get some help because I know that I would like to use my tccd instead of just using my herc.
Posted Sun 16 Dec 07 @ 9:04 pm
