When I try to install the new or old version of Catalyst drivers, I get this error right after the extract
INTERNAL FAILURE
Error Number 0x80040707
My card is a HIS X1950pro AGP
I know this is not a ATI forum but I could use the help
Thanks
INTERNAL FAILURE
Thanks
Posted Sat 01 Dec 07 @ 10:48 pm
Try this:
Create the folder Desktop in c:\documents and settings\all users\. After you do that install and it should work. I know it sounds really dumb but it works. Good Luck
Posted Sun 02 Dec 07 @ 12:23 am
Thanks I will try it
Posted Sun 02 Dec 07 @ 7:23 am
discobrian24
That did not work for me do you know of any thing els
Posted Sun 02 Dec 07 @ 12:05 pm
i have seen someone use a nvidia driver for there video card and it worked fine
Posted Mon 03 Dec 07 @ 1:48 pm
Ok search the web for Driver Cleaner Pro and try that. It will clean out all the ATI drivers in your system. I am tellin u I had the same issue some time ago and that folder trick worked. Did u download the correct drivers??
Posted Mon 03 Dec 07 @ 5:14 pm
Yes I am trying the new drives. My desktop fold was there already. I wlll try the Driver Cleaner Pro
Posted Mon 03 Dec 07 @ 7:47 pm
discobrian24
Thanks I was able to get it to work. Do you play games if so I am trying to find out something? I am run a (AGP Card) On a
p4 3.0E
motherboard ABIT IC7-G MAXII
Chipset Intel i875P/ICH5R
ram 2gib (pc3200)
video card HIS X1950pro AGP (512)
audio Sound Blaster Audigy 2 ZS
windows xp pro (sp2)
DirectX 9.0c
700W (PSU)
1. I am able to play Crysis on everything high but no AA or AF at 1210x1000
or
2. AA and AF on but at 1020x800 with everything at half
what do you think?
Thanks
p4 3.0E
ram 2gib (pc3200)
DirectX 9.0c
700W (PSU)
or
what do you think?
Thanks
Posted Mon 03 Dec 07 @ 11:40 pm
