Forum: Old versions
Topic: Volume Problem
The volume on my tracks keeps going up and down as the track is playing, not a lot but you could hear it fading up and down. Does anyone have an answer to the problem? Thanks in advance.
Posted Sat 13 Nov 04 @ 9:54 pm
do you have the limiter engaged? If so, disable it.
hope this helps.
What is the limiter? I don't have a clue of what you're talking about. I'm not a computer geek, so I need to be held by the hand. Thanks.
config/options->Fame settings->limiter...
Its not about computers, its about sound processing...
and dymamics...
you'd think they would read the user guide....good thing VDJ is so intutive.
When I disable the limiter it sounds awful. The tracks don't sound clear at all. And when I engage it, some tracks sound like the volume is going up and down. But, it sounds crystal clear. Please help with this sound problem.
Have the exact same problem, but no sollution....
Please help us.
/ Chris
do you have 2.05 ??
auto gain : always 0 db
limiter :activated
works fine for me
I do have version 2.05
Hello, this is carlos from cancun, méxico, actually i have the same problem (like that dude), when i´m playing a song, sometimes the volumes goes up and down, what does it happen, i was wondering if a have to convert the song format from mp3 to a wav file or what u guys recommend me to change that terrible sounds.
Thanks
limiter :activated
