whats going on everyone. i seem to have a sound problem with my mk2 . first when i try to record a tracks on my computer the sound is very low comppared to other mp3 files i have. and when i update the softwear on my mk2 the headphone controlls dont work correctlly . any idea what i can do. btw i am using vdj 3.4 and the mk2 is connected to my pc threw usb only. thanks
Posted Sun 25 Nov 07 @ 10:11 pm
have you downloaded pro?
you can upgrade to 5 free if you want to
on sound options you should choose
inputs : none
outputs : headphones
card : mk2
channels : 1/2 main 3/4 headphones
inputs : none
card : mk2
Posted Sun 25 Nov 07 @ 10:51 pm
i just did that thanks it works fine. but i still have the problem when i record a file it comes out sounding very low any advise?
Posted Sun 25 Nov 07 @ 11:03 pm
Go to ur herc control panel n set the volume 3/4.. n also check ur pc sound panel for the volume level;)
Posted Mon 26 Nov 07 @ 6:09 am
i tried that it wont let me choose 3-4 it only allows me to choose mic or 1-2 . but thats not the problem the thing is when i record . the sound of the file comes out low. the 1-2 port i just use that to go to my amp. in the record option i have-- record from master+mic and its mp3 file at 192 bit rate. any idea?
Posted Tue 27 Nov 07 @ 2:44 am
The default factory settings on the MK2 control panel are 1/2 volume for all four channels. What you need to do is adjust the sliders to max for both 1/2 and 3/4. I found this out the hard way setting up for a gig one fateful night (long ago, hehe) - cranked the amp, spent a half an hour troubleshooting, then...DUH! Worked fine after that :)
It's not a bad idea to check your windows soundcard settings in control panel also, but do it with the MK2 attached (the dialog box is different).
One more thing...Try recording from "Master" only, and see if that improves things. You can find more info. on page 50 of the manual. Good luck ;)
Posted Thu 29 Nov 07 @ 9:16 am
I was indeed refering to the slider.. i mean make it 3/4 of the total volume..
Posted Thu 29 Nov 07 @ 3:43 pm
