Hello Djs!
Can any one recommend a nice 2u rackmount case? I remember some time ago someone posted a link to a really small, nice looking one but I couldn't find that post anymore.
It'd be nice if the depth was no more than 45 cm.
Greetings, Cubalibre.
Posted Sun 25 Nov 07 @ 2:58 pm
I go with gator. Lightweight.
Posted Sun 25 Nov 07 @ 3:17 pm
Do you want the equipment RACK?
Or Computer case?
Or Computer case?
Posted Sun 25 Nov 07 @ 6:03 pm
I'm looking for a computer case to mount on a rack
Posted Sun 25 Nov 07 @ 6:35 pm
http://stores.ebay.ca/RackBuy-PLINKUSA-Net-RackOutlet
I bought mine from these guys.
Posted Sun 25 Nov 07 @ 8:07 pm
We are using this model
http://www.servercase.com/miva/miva?/Merchant2/merchant.mv+Screen=PROD&Store_Code=SC&Product_Code=GHI-252&Category_Code=2UE
2U and only 13.9" deep!
Posted Tue 27 Nov 07 @ 5:16 am
that's just what im looking for :) ty all.
Posted Tue 27 Nov 07 @ 12:59 pm
Be cautious about building a system in a 2 space rack.
The limitations of space may cause some heat issues. If your runnning VDJ with video there will be heat issues!
Also it's difficult to get additional cards, like video and audio to fit.
Even my 3 space case has had heat issues.
Posted Wed 28 Nov 07 @ 3:19 pm
when looking though the sight that marcel put up i do belive theres a card that you put in the video slot and it turns the video card 90 degrees so it puts it into a differant alignment as far as the the height of the case is concerned but i may be mis informed as to what that card was really for thats jsut what it looked like to me.
Posted Wed 28 Nov 07 @ 6:07 pm
