After installing the Hecules Dj Console (MK 1) and VDJ 5 rev 5 on my new notebook PC, I found that when switching the Hercules soundcard to DJ mode the internal EQ's dont work (Treb , Bass, Mid). for example when I click on the kill switches on the eq or play around with the virtual EQ knobs nothing seems to get affected. However once I switch back to NORMALl mode the EQ seems to work. I've never come across this problem and have no idea on how to rectify it. This cant be a midi issue as the knobs on my midi controller corresponds. Even if i use the mouse to click on the kill switches or adjust the EQ knobs it just doesnt work under DJ mode. I am able to move the knobs but there's absolutely no adjustment to the actual audio.
VDJ 5 rev 5 and the HDJ (Mk1) worked fine on my old system, but since my old system has crashed i have no way to test it out.
I'm running Windows XP Pro on the new system compared to running XP home on the old system. Im wondering if this is the issue.
I have tried both the 2005 & 2006 drivers for the MK1
Looking forward to some quick feedback. Hopefull
Thanks in advance.
Thanks in advance.
Posted Sat 24 Nov 07 @ 3:31 am
Problem fixed. Was a registry issue
Posted Sat 24 Nov 07 @ 5:17 am
