This is on the Pro version 5.5
1. No volume or gain. I have to rescan the bpm to fix. Why? I scanned all the tracks already. I have auto gain set to 0 db option.
2. As I mention that I have scanned all my tracks. Why does it auto bpm the tracks when I load it? It can change the bpm again. Annoying.
3. Can you add a feature to correct the bpm's with a 1/3? I find the 1/2 and *2 option is not always the solution.
4. Can you add a option to correct the bpm with more then just one track? Right now it only allows you to correct the bpm (1/2 or *2) one track at a time. I rather highlight a bunch of tracks to correct then one at a time.
5. Can you add a feature that allows the folders to be moved more then up or down one step? How about move to top or bottom? Better yet allow a drag and drop.
Otherwise a good job guys. Keep up the good work.
Posted Fri 23 Nov 07 @ 6:11 pm
WHY?
WHY?
Posted Fri 23 Nov 07 @ 9:20 pm
this seems to be a "wishes and new features" topic so it should be posted there.
Posted Fri 23 Nov 07 @ 11:00 pm
Sometime this happens to me also. Just adjust the gainknowb from the skin and it will be corrected.
Posted Sat 24 Nov 07 @ 12:42 pm
5. Why? I have a lot of folders and sometimes my ocd kicks in and I need to move a folder from the top to bottom really quick without clicking all the way down to the bottom. I may also add a new folder on occasion and want to organize it. It's just my ocd kicking in. :)
Posted Thu 29 Nov 07 @ 12:33 am
